Hello. I have the following problem: Master machine, which is held before me raised the temperature above the initial value, the toner will not burn the paper, when you scrape out a copy of the fingernail or toner is removed. Since we are also going to wrap the paper around the cleaning roller, so I think he wrapped the temperature is too high, I entered sp1105 and I returned value on initial value, the toner will not burn but is removed from the paper. I have tried over the instructions to change some value, but nothing helps. I do not know what to do anymore. It is the Ricoh Aficio MP 6500
Ricoh Aficio MP 6500 - Fusing Unit
Re: Ricoh Aficio MP 6500 - Fusing Unit
If you are using Ricoh type 6110D toner, please share a picture of the right hand side of the fusing unit. There are several issues that could cause that problem, and I would prefer to give you the correct information.
Thanks!
