Ricoh DV Unit # D0093010
  • Hoosierdaddy
    • Oct 2016
    • 182
    Anyone have a DV Unit # d0093010 from a machine in there boneyard they would sell (That Works) I have 1 that has bad bearings
  • sandmanmac
    • 3981
    Re: Ricoh DV Unit # D0093010
    Paddle roller bearing: B004 3059
    • sturmtrooper
      Copier Combobulator
      • May 2016
      • 587
      It takes some work but you can get the bearing out and replace it.
      This video will give you some help on that.
        • 37533
        I have also had bearings going bad round out the inside of the paddle roller drive coupling. If you have any old 35/45 ppm machine around it is the same coupling, PN B004 3078 Joint - Paddle.
