Error sc390 after 9 copies
  • vitalra
    • Feb 2017
    • 16
    Good morning, I had to add the toner in the development as it came out faded copies after adding a new toner refill. Now after 9 copies me out sc390 error, it seems that the coil of the toner does not rotate and accordingly does not descend in the development. solutions?
  • sandmanmac
    • 3981
    Re: Error sc390 after 9 copies
    It's ok, the model number is unimportant, there's many members here with psychic powers that will provide the solution shortly......
    • vitalra
      • Feb 2017
      • 16
      Ricoh mp2000 aficio
      • sandmanmac
        • 3981
        SC 390 TD sensor error: Defective TD sensor
        SC 390 TD sensor error: Poor connection of PCU
        • vitalra
          • Feb 2017
          • 16
          I understood the toner density sensor, I have to replace it? there is something to check? you can try to reset and how is it done?
          • davel
            • Oct 2011
            • 1107
            call a trained technician or update machine.
            • bob marley
              • Jan 2012
              • 1339
              Toner supply could be defective
              Live for yourself and you will live in vain. Live for others, and you will live again
              • sandmanmac
                • 3981
                This wouldn't cause an SC and the machine would just be in a constant "add toner" condition
                • vitalra
                  • Feb 2017
                  • 16
                  I explain what I did: I replaced wiper blade and drum after 65,000 copies, coming out dark and dirty output. Watching a video on the internet on how such maintenance was made and I also removed the printer toner more in group development and added the original one of the toner bottle. I cleaned the upper mirror you see the left side of the glass scanner because it was striped of the press. then suddenly 390 error after 9 copies.
                  • sandmanmac
                    • 3981
                    I'm not sure exactly what you're trying to say here, but it sure sounds like you may have emptied the developer unit.
                    Whatever the case, you're now in even more over your head than when you started.
                    Good luck
                    • copyaction
                      • Oct 2007
                      • 991
                      Good luck
                      it sounds like you nailed it, he emptied the developer and filled it with toner.
                      • NeoMatrix
                        Senior Tech.
                        • 3513
                        [remove google translate]
                        Original problem sounds like under toning.
                        Could it have been a second toner cap stuck in the toner hopper?
                        • vitalra
                          • Feb 2017
                          • 16
                          [QUOTE=NeoMatrix;552653][remove google translate]
                          Could it have been a second toner cap stuck in the toner hopper?[/QUOTE
                          in the print development group does not reach the toner bottle?
                          • TonerMunkeh
                            Professional Moron
                            • 3865
                            Fit a new bag of dev, B121 9645. The toner won't give the TD sensor any readings, hence the 390.
                            Hit it.
                            • vitalra
                              • Feb 2017
                              • 16
                              as the difference between the original toner bottle and this B121 9645?
