Ricoh 2035
  • tcypy1961
    • 773
    Ricoh 2035
    Is there any way to get this copier to print using windows10??? Copier was printing until the change to windows 10. Thanks!!!
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 587
    Re: Ricoh 2035
    That machine is ancient.
    Aficio 2035/2045 download page
    If you are lucky the windows 7 driver will work, if not try the universal driver.
    Otherwise you could try setting up a print server on a windows 7 machine.
    • copyaction
      • Oct 2007
      • 991
      Re: Ricoh 2035
      I have 2022's printing on windows 10, there shouldn't be an issue since it is from the same era
      • COPIERMAN
        • Jun 2009
        • 559
        Re: Ricoh 2035
        windows 10 select print isn't listed above and select manual settings then select ip address of copier. I check ricoh website they have driver for windows 7 64 bit so that driver should work with windows 10.
        Last edited by COPIERMAN; 02-23-2017, 09:11 PM. Reason: look at ricoh website for driver
        • sandmanmac
          • 3981
          Re: Ricoh 2035
          If the 2035 driver isn't listed (and I doubt it is), pick a RICOH PCL driver, any RICOH PCL driver. No problem
          • mfrigault
            • Feb 2017
            • 18
            Re: Ricoh 2035
            Try this link:
            Universal Print Driver Downloads | Ricoh Global
              • 37494
              Re: Ricoh 2035
              Originally posted by mfrigault
              The only time the Universal Print Driver should be used is when you need to pool two or more different models. Pooling requires that all printers within a pool use the same exact drivers.
              • andrewdecruz
                • Jul 2009
                • 74
                Re: Ricoh 2035
                There is no drivers for Ricoh 2035 under Windows 10, but you can choose one from Windows 7 - 64 bit. As this model is already 14 years old (Introduced in 2003 and discontinued in 2005 ) it's therefore logical that Ricoh has not updated it's manufacture drivers beyond Windows 7. You should seriously consider upgrading this machine. It will cost you a bundle just to keep it working reasonably well.
                • rthonpm
                  • Aug 2007
                  • 2854
                  Re: Ricoh 2035
                  The Windows PCL drivers by Ricoh are identical for each model: the Windows 7 driver is the same file as the Server 2012 R2 driver. The Windows 7 or 8 driver will work with Windows 10 without any issues.
