Ricoh MP C3003- Print Spooling 10+MB file
  • Methedor
    • Nov 2016
    • 69
    [Misc] Ricoh MP C3003- Print Spooling 10+MB file
    Serial: W493L200860
    Apologies if this is the wrong place as this has aspects of printing and networking.
    I have a client wanting to print a 10+MB (14.4MB to be exact) and looking at the queue, it spool blooms to 47MB taking a long time to print. Client said an hour til it printed, I'd guess slightly less than that, but still far too long.
    I have tried Direct Printing which has failed to accelerate the matter. I have enabled Spooler Printing via the WIM, tired EF 1.008 (under print processor), switching from WSD to IP\Port, shrinking the image scale to at the PC print screen, switching to Print after last page spooled, Stop and Start (not Restart) Print Spooling Service; all didn't resolve the issue.
    The client is not willing to edit image size on 10+MB files to reduce file size as I had done that with the image and it did print. They are also not willing to give the photographer instructions to not send such large files to them.
    Client PC information (Though there will be MACs introduced later.)
    Windows 10 Home 64-bit on HP computer
    Connected to network via Network Cable (Assuming Cat 5e)
    So in my effort to do research on the matter I wish to query the brain trust.
    Here is my research thus far.
    Print Spooling Issue (Possibilities)
    0) Postscript (?) [[PS3 on order for device]]
    1) Try PCL 5 Driver
    2)Clear Printer Spooler Files and Enable the Spooler Service
    1. Click Start, type "Services.msc" (without the quotation marks) in the Start Search box and press Enter.
    2. Double-click "Printer Spooler" in the Services list.
    3. Click Stop and click OK.
    4. Click Start, type "%WINDIR%\system32\spool\printers" in the Start Search box and press Enter, delete all files in this folder.
    5. Click Start, type "Services.msc" (without the quotation marks) in the Start Search box and press Enter.
    6. Double-click "Printer Spooler" in the Services list.
    7. Click on Start. In the Startup Type list, make sure that "Automatic" is selected and click OK.
    3)"One way I found around this was to add the printer as a local printer pointing to the port - as opposed to connecting to it mapping across the server. As soon as I did that, print speed was normal.
    4)Shorten Printer Name (maybe)"
    Thank You for Reading and Responding
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Re: Ricoh MP C3003- Print Spooling 10+MB file
    Lots of good info, but you did not say what application you are printing from.
    Word? PDF? Something else?
    Unflattened PDFs can grow to MANY times their original size. 4+ is actually pretty low.
    47 MB or so is not all that large a spool file to deal with; that in and of itself shouldn't matter.
    Did you try an LPR port, instead of Standard TCP/IP? That may help. It's supposedly not as chatty. WSD ports need to die; they SUCK, period.
    I think that model has the PDF Direct feature, which will allow you to LPR a PDF to it directly. In the past, you needed PostScript to do that. If you can, it will eliminate any driver issue, as it won't use one. No finishing, of course, but a good troubleshooting tool.
    Please feel free to post back if you don't know how do do that, or search CTN for it. I know I have posted it at least a few times over the years.
    The PostScript option is almost never a bad idea, especially if you are printing from a PostScript based app, such as most Adobe products. Not likely at all that MS Office apps would benefit, other than possibly Publisher, although Publisher has a myriad of its own issues when it comes to printing - it can be painful.
    • Methedor
      • Nov 2016
      • 69
      The Win 10 picture Image Viewer in this case a Jpeg. I cannot change the methods of view\print very much due to the clients preference.
      I'll add the LPR to my list, thank you.
      I hope that extra bit of info helps
        • 37495
        You said you have order PS3 option so I take it that you are currently not using PostScript. I hope you are not using the Ricoh type driver that wimodws automatiicly installs as it can take minutes to spool a 1 page document. If using the Ricoh PCL6 for this model, not the one for universal print as it is also slow, check printer preferences - Print Quality - Vector/Raster. Try both settings. I had a church where changing this change an 8 page 8 1/2 X 17 folder over bulletin from over 30 minutes to spool to about 1 minute. Also check the resolution. Use the lowest setting that gives acceptable image quality.
        • Cipher
          It's not easy being green
          • May 2006
          • 1309
          Originally posted by Methedor
          Serial: W493L200860
          It varys but print jobs should be spooling in excess of an 1Mb/sec over an network connection (if not faster).
          I'd check out why the connection speed is so slow.
          • TonerMunkeh
            Professional Moron
            • 3865
            Unfortunately, the MPC3003/3503 have really, really slow controller processors and take forever to spool large print jobs. It has been acknowledged by Ricoh Japan. The only fix is to put a 4503 in there, they have the faster chip.
            Hit it.
            • Gift
              • Mar 2011
              • 2459
              Try hook up your laptop with a cross cable and you can probably proof that this is not a machine-wise performance isssue....
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3944
                I agree!
                My previous suggestions were to only try to make the best of what's there.
                The C3003/3503 is quite slow compared to most.
                "You can put lipstick on a pig, but at the end of the day, it's still a pig", as the saying goes.
                • Cipher
                  • May 2006
                  • 1309
                  Very slow to load up from off and to update, but can't say I've noticed slow spooling speeds though.
                  Certainly not up to an hour for a mere 47Mb.
                  We would have customers complaining left, right and center if that was the case.
                  • Methedor
                    • Nov 2016
                    • 69
                    At my office I did a test print of ~13.3MB colored Fantasy map image to our MP C3002.
                    I am using Windows 8.1 and a PCL 6 Driver, default spool settings using a wireless connection. (~2.1Ghz dual core, 16GB RAM)
                    Attempting to use the print from the image viewer has trouble rendering the preview (The viewer can too); printing gave a black image (and there goes a bit of toner, hehe). Though the Black Image did print quickly.
                    I opened it in Photoshop and selected scale to fit as the only adjustment and in 16-20 seconds it printed.
                    Maybe I should image-copy my HDD to their system.
                    • Methedor
                      • Nov 2016
                      • 69
                      Ok an update as of 3/1/17.
                      Connected my laptop directly via network cable and got the same results in print speed as I did with the office test, I printed via Photoshop to avoid the black image issue.
                      I couldn't find a RPCS Driver as they seem discontinued and those I did find were for the wrong model (IE. MPC3300).
                      Tried the following without positive result:
                      PCL 5
                      Cleared Print Spooler Folder
                      Changed from Vector to Raster
                      Set Host interface to second, higher I\O setting
                      Ricoh and Ricoh Plus Driver
                      Deselected SNTP on port
                      PCL Universal v4
                      There was a few setting that had the queue state it was printing, but sitting at the Max\Max without actually printing.
                      I need to look into LPR printing (Though I did switch the TCP\IP from RAW to LPR with a number put in the queue)
                      Need to look into Windows Postsript printing as the Photo Viewer wasn't finding the printer when I installed the Driver.
                      While I am not too familiar with MAC, I imagine I can use a printer share and have it render the print job on the MAC sing PS.. provided I can connect it to the same network after talking to the IT guy.
                      Thank you for Reading and Continuing to Assist
                      • COPIERMAN
                        • Jun 2009
                        • 559
                        I don't know but I see getting it by email. have them try saving it to computer then try printing it. i had a client that when she received it take a long time to print but if save to computer it would print normal.
                        • Methedor
                          • Nov 2016
                          • 69
                          Thank you for the response, however, the file is on their system vs print from e-mail attachment.
                          • KenB
                            Geek Extraordinaire
                            • Dec 2007
                            • 3944
                            What format is the file: TIFF? BMP? JPG? etc...?
                            • KenB
                              Geek Extraordinaire
                              • Dec 2007
                              • 3944
                              Nice suggestion, but even if it really sped things up, NOT a practical solution.
