Ricoh MP 4002/5002 Web GUI password reset
  • havokprod
    • Oct 2012
    • 159
  • havokprod
    • Oct 2012
    • 159
    Re: Ricoh MP 4002/5002 Web GUI password reset
    On another note this machine and a few others I have are off lease from a bank (Bank of the West) so I am assuming the security was high.
    • sandmanmac
      • 3981
      Respectfully,
      You can't think that you're the first person to experience this situation?
      There must be dozens and dozens of threads relating to the WIM password.
      I feel that's why the responses have been slow....most of us are simply tired of discussing it.
      The best tip I can give you is to disregard your specific model number, and just search the Ricoh Forum, because the process is the same for almost every model (except for the really old ones)
      There are ways to reset the Credentials. Some free. Some at a cost, and some very complicated.
      Here's a few threads to get you started:
      LMGTFY
      • nadimtopsecret
        Experienced Tech
        • Mar 2013
        • 47
        As you checked every primary suspected option and not solved so I'll suggest you to replace the NV RAM. Cause few days ago I also solved that issue by replacing NV RAM.
        • Elmo
          • Feb 2010
          • 541
          as sandmanmac said there are loads of threads about this
          you DO NOT need to replace the nvram
          you DO NOT need to memory all clear
          I Used To Live To Fix Things Now i Fix Things To Live
          • mikadonovan
            • May 2008
            • 2931
            Too late.
            Originally posted by havokprod
            I have also ran SP5801-1 Data Erase All
            NEVER ASSUME ANYTHING
            • havokprod
              • Oct 2012
              • 159
              Originally posted by sandmanmac
              Respectfully,
              LMGTFY
              Ok I'll re-read those threads again......
                • 37532
                And there in lies your problem.
                Also there is a setting in System SP that disables WIM.
                • havokprod
                  • Oct 2012
                  • 159
                  Figured it out SP5846-46. I also tried the Hex editor method, unsuccessful there. Thank you all
                  -havokprod
                  • loading
                    • Mar 2013
                    • 13
                    This is a PUBLIC forum and no place to post such info..... even though it's been done in the past!!
                    The original poster even managed o find it before you chimed in
                    You can still redeem yourself by deleting the post. Then I'll delete this one
                    Ihavedeleted
                    • sandmanmac
                      • 3981
                      Originally posted by loading
                      Ihavedeleted
                      Thank you
                      • tufbnme
                        • 493
                        Originally posted by mikadonovan
                        Too late.
                        Now your in deep, too late means too bad.
                          • 37532
                          -havokprod
                          That will only reset admin and supervisor to factory default and clear address books.
                          • Zoran
                            • 51
                            A
                            replace nvram
                            B1
                            the copier without PASSWORD
                            1. Turn the main power switch ON.2. Access SP5990-001 and print out all data lists.
                            2. Turn the main power switch OFF.
                            3. Insert the SD card into the lower slot on the controller box.
                            4. Turn the main power switch ON.
                            5. Upload the NVRAM data (SP5-824-001) onto the SD card.
                            6. Turn the main power switch OFF.
                            file on the SD card will have the name of the case V6903000073.nv
                            B2
                            the copier PASSWORD
                            file on the SD card will have the name of the case V6903000111.nv
                            files preserve
                            files preserve
                            B3
                            the correct file witout pasforda (V6903000073.nv)
                            change the name in (V6903000111.nv)
                            1. Insert the SD card into the lower slot on the controller box.
                            2. Turn the main power switch ON.
                            3. Download the NVRAM data (SP5-825-001) stored on the SD card .
                            4. Turn the main power switch OFF.
                            5. Remove the SD card from the lower slot in the controller box.
                            6. Turn the main power switch ON.
                            7 Access SP5-811-001 and program the machine serial number.8. Access SP5-811-004 and program the BCU serial number.
                            9. Hdd format..
                            If not
                            replace the old NVRAM settings.
