Aficio 1035/45 & Savin 2535/45 Parts Interchangeable?
  • sherman
    • Dec 2007
    • 17
    Hello,
    Quick question are boards (BICU, SBU etc...), and key control panel interchangeable on the AFICIO 1035/45 and SAVIN 2535/45? Would I be able to swap some or all of the boards from one machine to another?
    I have a SAVIN 2535 and I need BICU and keypanel. I was planning on purchasing used AFICIO 1035 for the parts.
    Thanks.....
  • ZeusGT
    • 271
    Everything will interchange from a Savin 2535 to a Ricoh 1035.. they are the same machine from the same generation. If you are going to interchange the BICU, I would take the NVRAM off the old one and put it on the other one that you are going to interchange it with.... Good luck
    CompTia A+ Certified
    CompTia Net+ Certified
    CompTia Server+ Certified
    CompTia Project+ Certified
    OP Scanshare Certified
    • sherman
      • Dec 2007
      • 17
      Thank you..
