sc552 error code On ricoh mb5000b
  • feroo666
    • Dec 2014
    • 23
    after I change
    Teflon Roll On my
    ricoh mb5000b machine it didn't work still show sc552 error can i fiend any solution
  • samadshafi
    • Mar 2017
    • 16
    Re: sc552 error code On ricoh mb5000b
    This error is a fusing thermistor error, it can mean:
    The fusing lamp is not connected. Reconnecting it may solve the problem.
    Thermistor is bent or gone bad. You may need to replace it.
    Or, the thermistor position is incorrect.
    To try and reset the code press:
    Clear Mode, 107, Clear/Stop and hold for 5 seconds. Swich off and on the machine
      • 37490
      If you replaced the Teflon roller because of the SC 552, you replaced the wrong part. As samadshafi said, SC 552 is a thermistor error. After you repair the cause of the error, you have to reset the code with SP 5810 SC Reset. Before hitting execute, make sure you have SC Reset.
      • Ricoh-ono
        • 338
        There is not an SP 5810 for a b/w MP5000.
        Sent from my SM-G900V using Tapatalk
        Do what you can, with what you have, where you are. ~Theodore Roosevelt
        • davel
          • Oct 2011
          • 1104
          Look in your manual again, SP 5-810 reset fusing SC.
