af 2022 toner not cacked on paper.
  • Gab
    • Aug 2015
    • 671
    after some copies press roller is removed from the proper position. And as a result press and hot roller doesn't press each other at the right side. When i put it at the right place after some copies it removes from the proper potition. Any idea how to fix it?
  • StephenB
    • Aug 2015
    • 244
    Re: af 2022 toner not cacked on paper.
    Gab,
    Look at your lower press roller bearings. Old style (very old) did not have a "groove" in them, the groove secures the bearings in place.
    • tufbnme
      • 493
      The housing is more than likely broken allowing the UFR to slip sideways. Either replace the housing or use an ufr bearing with a collar (thats what I do)
      Very common problem
        • 37529
        Very common problem
        I used to use a heavy paper clip to MacGyver a holder to keep the bearing in place until the housing could be replaced.
        I did have one machine where the bushing holder for the pressure cleaning roller was broken. This caused uneven pressure on the pressure roller and made it move out of place. Only solution was to replace housing.
