MPC2500 Yellow
  • blackdog
    • Jun 2012
    • 211
    MPC2500 Yellow
    Hey fellow Techs I looked through Threads for this issue to no avail.
    Yellow toner build up on rear side of PCU causing a parotic yellow image on rear side of prints.
    There is a yellow toner build up on top of PCU Cleaning blade toward rear only.
    New Drum, Blade, and Transfer Cleaning Unit. I find yellow toner on rear side of secondary transfer roller as well.
    This issue is yellow only.
    OEM Toner used. 250k on box.
    I hope someone has had this problem as I really don't want to keep shooting in the dark.
    Thanks for your help.
    • 37532
    Re: MPC2500 Yellow
    Sounds to me like it is time for a new drum unit.
    • bob marley
      • Jan 2012
      • 1339
      Re: MPC2500 Yellow
      Originally posted by blackdog
      New Drum, Blade, and Transfer Cleaning Unit. .
      seems u need a new developer
      Live for yourself and you will live in vain. Live for others, and you will live again
      • sandmanmac
        • 3981
        Re: MPC2500 Yellow
        I Agree with Slim. Replace PCU at a minimum, and probably add a bag of yellow dev. These units are not meant to be rebuilt, so while you say you're using OEM toner, apparently you're not using an OEM drum
        • blackdog
          • Jun 2012
          • 211
          Re: MPC2500 Yellow
          Gentlemen Thanks,
          Looks like I'll have to bite the bullet and do a new PCU.
          Contract machine you know how it is. $$$$
          • blackdog
            • Jun 2012
            • 211
            Re: MPC2500 Yellow
            Hey wanted to follow up on this thread.
            Seems my cleaning charge roller with Dirtex wasn't good enough so I grabbed some Brasso, you
            know the shit we used in the Military to spiff up our Brass.
            Well the print quality couldn't be any better now.
            To bad charge rollers weren't readily available. Seems a waste to prematurely fill land fills with perfectly good PCU's.
            • sandmanmac
              • 3981
              Re: MPC2500 Yellow
              If it's the old style (black coating) PCR, I use car polish (like turtle wax, etc.). Works GREAT.
              If it's the new style (Greenish coating), I scrub that surface off like a scratch ticket - right down to the nylon roller
              • blackdog
                • Jun 2012
                • 211
                Re: MPC2500 Yellow
                Turtle wax gives a hard shell finish. Some truth to that huh.
                  • 37532
                  Re: MPC2500 Yellow
                  When the charge roller cleaning roller starts to deteriorate, you would need a new one of those as well. The key item to the overall life of a PCU is the coating bar. Once it is gone it the end of the drum.
