Hi. Got a mpc3003 that's all of a sudden on a medium run 15 plus pages the fusing gets quite patchy. We use compatible toner and been ok so far, also same 80gsm paper. The copier has done 25k in total. By setting to thick1 fixes the problem but for some reason when i print from the computers it only prints 1 page from a job and cant staple saying paper too thick. I get the stapling but printing surely it should print all or nothing at all as media is a mismatch. Would you say it needs fuser parts or its down to compatible toner? Please see example. Also it appears to only offset the black as colour writing on top is ok, or possibly issue with the heat in the middle.
Cheers
Cheers
