Hi, All. I am trying to set the scanning screen so that the FOLDER tab is automatically selected instead of the email tab. I tried to use the ol "program as defaults" way, but it does not work. Is there a way to do this?
C5502 scanning screen default
Tags: None
Re: C5502 scanning screen default
Never mind, I fixed it. Just had an idiot moment.NEVER ASSUME ANYTHINGComment
jono.hbtech
Hi Mike, to fix this you will need to go to the usertool/couter button. Then click on scanner features. under the general settings tab, click on the "destination list display priority 2 button. It will say Email Address next to it, change this to folder and it is all done. Hope this helps? Cheers Jono.Comment
Hi Mike, to fix this you will need to go to the usertool/couter button. Then click on scanner features. under the general settings tab, click on the "destination list display priority 2 button. It will say Email Address next to it, change this to folder and it is all done. Hope this helps? Cheers Jono.NEVER ASSUME ANYTHINGComment
