Ricoh Aficio 2045 scan
  • mkopoiuy
    • Mar 2008
    • 54
    I want to use scanning to send email from the Aficio 2045.
    but m/c shows "add sender's name"
    So I was trying to add sender's name but I couldn't find how to add sender's name.
    Anyone could help how to use scanning function not only adding sender's name.
    I am a beginner for this m/c.
    thank you.
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    Basically, you need to fill out the "to" and "from" fields in the email before it can be sent. You can do one of two things. You can either set up the scanning destinations as senders, or add an email address to the key op field and this can act as the default "from" address.
    • service bod
      • Jul 2008
      • 14
      Scan to email
      You could also set an admin email address in the machine i normaly create an address like copier@(company name).com or co.uk it doesnt have to be a real account.
      and then set automaticaly specify senders name.
      This serves two purposes:
      1) you dont have too enter it every time.
      2) when you recive the email from the machine you know it is a scan job
      from the copier.
      • mkopoiuy
        • Mar 2008
        • 54
        thank you very much.
        I really appreciate.
        • mkopoiuy
          • Mar 2008
          • 54
          need more help
          can someone please help with the scanning process step by step, it still will not work for us?
          We selected the scanner than enter the email but it says sender name is not there, where can we find the from selection
          • rthonpm
            • Aug 2007
            • 2859
            It sounds as if when your address book entries were set up, you didn't specify any users as both destinations and senders...
            User Tools
            System Settings
            Key Operator Tools
            Address Book Management
            Go to the name(s) you want to allow as sender(s) and when you press the key for them:
            Email
            Register as Sender
            ON
            I hope this helps...
            • scoobysteve
              • Jun 2008
              • 163
              If you fill in the Key Operator's Email address will an address that works ie, if the client's SMTP server is located at the ISP, then the email will have to be one that is valid on the ISP, it just can't be copier@isp.com,. If the client is running MS exchange, then it can be copier@domain.com as per what Service bod mentioned previously.
              Now that that part of it is sorted, if you go to User Tools, Scanner Features, Key Op Tools, you turn on "Specify Senders Name". this will use the Key Operator's Email address mentioned above as the default sender.
              The above tips are if you dont not want the clients to have to manually specify a sender everytime they scan to email.
              If you want the clients to select themselves as the sender everytime they scan, you will have to do what rthonpm has mentioned.
              Hope this helps.
              • mkopoiuy
                • Mar 2008
                • 54
                thank you all of you replied to help.
                appreciate.
                • mkopoiuy
                  • Mar 2008
                  • 54
                  I am getting a warning that sending has failed and that data will be resent later. Can you please tell me what that means and what should I do.
                  • scoobysteve
                    • Jun 2008
                    • 163
                    Hi,
                    First of all, i am assuming you are scanning to SMB as you have posted in my post about SMB scanning.
                    this problem can be quite complex depending on how your network is configured (is a small business or does it expand a WAN?).
                    this is how i will test it... remove any username and passwords from the machine - if you have several users, just remove the username and password for the user you are using to test as well as the username and password under "File Transfer" --> "Default Username/Password (Send)".
                    Then go back into the profile of your user that you are testing and select the "Folder" tab. Ensure that the path to the destination is set manually. Dont worry about doing the communication test yet. Instead press the "Browse" button. If you copier can see the path it will ask you to enter a username and password. If it cannot (for whatever reason, eg, unable to resolve hostnames, firewall blocking SMB) then you will NOT get the prompt to enter username and password. If this last scenario is the case, then i will not be able to help you without any more info as each network is different.
                    hope this helps...
                    by the way, the SMB bulletin that was mentioned in the previous posts resolved my problems.
                    • WiseWun
                      Ricoh 2027 Scan to folder error
                      Hey guys, I have the same issue but slightly different because its a different model and it's about scan to folder (smb) rather then e-mail. I was able to scan to folder over the network until I got this message "Sending the data has failed, the data will be sent later." Any help or advice would greatly be apprecaited.
                      • scoobysteve
                        • Jun 2008
                        • 163
                        hi,
                        Are you aware of any username/password changes? if so, it may be because the credentials being used have also been changed (ie password change) thus making SMB scanning fail.
                        The best way to check is to go into the address book management from the Copiers Control Panel, select the user you wish to test. Select the folder button and then click on the "Browse" button. If you get a cannot login with entered username and password, then you've had a username or password change. if you get connection failed, then go the to the Auth Info button/tab and turn specify folder authentication to "off" if it is on. If you do not have a username and password here, go back to the file transfer tab under system settings and scroll down to Default username/password (send) and delete the username and password for SMB. then redo the "Brwose" test. if you continue to get connection failed, then you've got other problems such as the shared location is no longer shared, could be a DNS issue is the hostname of the PC hosting the shared folder is being used, the actual PC hosting the share is no longer available and so on.
                        hope this helps
                        • WiseWun
                          Looks promising! Thanks.
                          Thank you very much scoobysteve, i'll give that a try tommorow morning. First thing that came to my mind was password change, however, the user can't change their own passwords and I have asked them just to make sure. I really appreciate your prompt response, will give you an update.
                          Cheers,
                          WiseWun
                          • KopyKat
                            Nurse Ratched of Repair
                            • Nov 2008
                            • 365
                            Here are two white papers which will walk you through both scan to folder and scan to email. I find using the web image monitor (browser interface) to be the easiest.
                            sigpic
                            Relax! This firmware injection won't hurt...but it will take 45 minutes.
                            • geseymour
                              Re: Ricoh Aficio 2045 scan
                              Hi,
                              I am having issues getting the new Savin C305 to scan to e-mail. The installing company performed their services in getting everything but this feature working. We can fax and scan to folder, but cannot scan to e-mail. I have tried a couple of documents without success. Is there anyone out there that can help? The error is "Sending the data has failed. To confirm the result, check [Comm. Status/Print]". Any help will be greatly appreciated.
                              Regards,
                              Gary
