Error code sc 702-03
  • wouterp
    • Dec 2014
    • 8
    [Error Code] Error code sc 702-03
    Ricoh MP2501SP experiencing sc 702-03 when document feeder is plugged in. Changed most of the boards and most of the harnass. Still no joy. Machine operates fine otherwise except cannot use the document feeder
    Sent from my LG-H815 using Tapatalk
  • Rorschach
    • Nov 2008
    • 64
    Re: Error code sc 702-03
    If you've done the boards and some harnesses, check the feed and transport motors as well as the pick-up and inverter solenoids. That, or perhaps one of the harnesses you didn't do yet is shorted.
    Today's subliminal quote is:
