Ricoh 8000MP
  • Leon_Barrett
    • Jul 2025
    [Jamming] Ricoh 8000MP
    Having a 'mare with J023 Jams,by swopping the duplex and finisher with a identical device ,those items on the other device hasn't incured any faults,replace 2 exit sensors on left hand side of fuser section also,but still J023. Does anyone think it could be sensor on the assembly next to fuser/pressure rollers? any suggestions will be accepted with thanks
  • MIKON
    • Jul 2015
    • 187
    Re: Ricoh 8000MP
    Check this sensor see if sensor flag is hanging up.
    • Mike Watson
      • Oct 2012
      • 13
      Re: Ricoh 8000MP
      Hi :-)
      Which sensor is this as i also have the same fault, tried changing the duplex, transfer belt unit and the fuser unit but still having the same fault :-(
      Many thanks
