Ricoh Ft 4118 need to adjust exposure amd vsg
  • Papo
    • Oct 2008
    • 36
    Cant find any documentation on this model need to darken up exposure and adjust vsg how do i get into sim mode ? What code should i use?
    Any help would be apreciated!
  • Voltage
    • Jul 2008
    • 282
    There is 2 ways of getting in the SP modes
    1. Press "All clear" (Yellow Button), "Stop Button" (Red Button) and then "#"
    In this mode you have to press "." and then "#" to enter a value
    2. Remove the back cover and set Dip Sw 4 on mainboard to on.
    SP 48 = Exposure Lamp Adjustment.
    SP 54 = Is Vsg. (To adjust the Vsg adjust the POD on the mainboard. Think
    its the top one. VR101 or something. Memory is letting me
    down)
    SP 55 = Vsg & Vsp (If i remember correctly you hold in "0" to get the VSp)
    Hope this helps.
