Cannot print from USB to M2852
  • AjitN
    • Mar 2009
    • 287
    [Misc] Cannot print from USB to M2852
    Purchased Used Ricoh MP 2852 wherein all functions are good except No printing from USB.
    Nothing happens when pen drive inserted in both the slots.
    In service mode ON BOARD NIC & USB is active.
    Performed all memory cleared, Coping-printing- scanning is OK, except USB printing.
    Thanks in advance for any help, suggestions.
  • nadimtopsecret
    Experienced Tech
    • Mar 2013
    • 47
    Re: Cannot print from USB to M2852
    Sorry to say, I'm not cleared about your question !
    Are you trying to print from USB Pen drive or USB Mass storage device ? Or by from USB Printing Cable ?
    • davel
      • Oct 2011
      • 1107
      pretty sure you can not print with the 2 usb on back. have to use usb on op panel.
      • sandmanmac
        • 3981
        .....which is optional on this model
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          Not sure, but I think the giveaway is "both slots", which implies that you are putting the jump drive in the slots at the back.
          Not to mention how totally impractical it would be to fumble around trying to reach the rear USB ports on a regular basis.
          • Polarbear
            • Feb 2012
            • 1070
            "Nothing happens when pen drive inserted in both the slots."
            Press the GREEN button!!
            • nadimtopsecret
              Experienced Tech
              • Mar 2013
              • 47
              May be your machine's Media card slot is disabled. Please check that settings under "User Tools/Counter" menu.
              Here I attached the picture instruction.
                • 37533
                The SP setting for ON BOARD USB is for the single USB port where you connect a computer, not the 2 USB slots where you can connect a USB memory device. Go to USB2.0/SD SLOT TYPE H in the installation portion of your service manual and change the SP settings given there.
