MPC4501 and MAC problem
  • Staggan
    • Jan 2017
    • 54
    Hello
    I am trying to install an MPC4501 on a network for use with a number of MAC's... it was working until someone changed the router they are using.
    The copier is attached to the network and from the web browser on any of the machines I can access the it... however, when I ask the MAC to add it as a printer it is not found..
    I have tried letting the MAC look for the printer, which shows nothing, and adding it using the IP address.
    The only issue I can see is the connection between the copier and network gives some fluctuating ping results...
    Anyone have any ideas?
  • guitar9199
    • Sep 2016
    • 1100
    Re: MPC4501 and MAC problem
    Originally posted by Staggan
    Hello
    First step...set the copier on a Static IP that is outside DHCP range. (ie: Computer is 192.168.1.18...set the copier to .160 or something like that)
    Next...You REALLY don't want a Mac to "search" for a networked printer. The best process is to first, install the print drivers for the specific model... then go into System Prefs and add the printer using IP protocol, enter the IP address and then "Select Printer Software". Once it's installed, it's easier to configure the printer using the CUPS (Common Unix Printing System) interface.
    The only other thing I watch for is to set the print protocol to "Line Printer Daemon", and use "lp" as the name of the print queue.
    Good luck,
    • Staggan
      • Jan 2017
      • 54
      Hello
      I normally set the copier to DHCP first to make sure it can find the network etc.. then I choose a static IP outside the current range... normally XXX.XXX.XXX.199 or something...
      I did use the IP to manually install the printer and I had already installed the latest driver....
      I did not however set it to use LPD..
      I will check this...
      • PinevskiS
        • Jul 2009
        • 283
        Istall driver with GUTENPRINT
        • StephenB
          • Aug 2015
          • 244
          If it worked before the router was replaced, it appears that the Gateway ( and or Subnet Mask) have changed. Put back into a DHCP let it pull the network settings,
          then put into a static IP ( outside the reset range ) With Macs, they are almost always an easy set up and will find and install printers ON the network.
          • Staggan
            • Jan 2017
            • 54
            As I said, I always put the machine into DHCP mode first to make sure it is finding the network properly... and then I set it to static...
            As I said, the strange thing is that I can access the machine from a web browser on the network using the assigned IP address, but the MAC's are not finding it... either automatically or using the IP address....
            • TonerMunkeh
              Professional Moron
              • 3865
              Could the new router have Bonjour disabled, or it be disabled on the MFP?
              Hit it.
              • Staggan
                • Jan 2017
                • 54
                Thanks for all the suggestions...
                In the end I reset the new router, turned ALL networked equipment off, set the copier to DHCP, let it get an IP address, set that as static, added an exclusion in the router for that IP, restarted everything else... and it is now working.....
                Thanks again
                • davel
                  • Oct 2011
                  • 1108
                  Thanks again
                  I hope you set the router to use the same IP range as the original one.
                  • rthonpm
                    • Aug 2007
                    • 2860
                    Never a good idea: this is just asking for repeated calls from the customer for why feature x or y doesn't work like it should.
