MP W3601 LPH REPLACEMENT
  • rsyarcia
    Hair Straightener Tech
    • 711
    Doc1.pdf
    Hello experts, we have replaced a LPH ASSY on a MP W3601 machine. We input all the settings from the new LPH assy to the machine. Adjustments have been done, LPH 2 and LPH 3 is ok but LPH 1 copy quality differs a lot.
    Anybody has this issue before. Thank you for your support.
    Nobody is perfect..
  • laitang
    • Nov 2012
    • 627
    Re: MP W3601 LPH REPLACEMENT
    Did you perform SP2952-11 to adjust the position of LPH 1? (LPH 1 is lower than LPH 2 -> set a smaller value.)
    • Brianneoe
      • May 2015
      • 322
      If you mean that the quality is poor or fuzzy then I would recheck that the unit is sitting correctly in place.
      • rsyarcia
        • 711
        Yes, we followed the adjustments from the service manual.
        Nobody is perfect..
        • mikadonovan
          • May 2008
          • 2931
          Adjust 2943-1 to a higher value (LPH1 density adjustment), or adjust 2943-2 & 3 to a lower value. I see you also mentioned copy quality, so make sure the light blockers are in place and the white plate is clean.
          NEVER ASSUME ANYTHING
