Multiple Errors
+ More Options
Posts
  • nysamara
    • Apr 2016
    • 58
    #16
    Re: Multiple Errors
    Current status!
    I resolved all the errors and restored the birth certificate information...
    I was able to do copies... and machine did a good printing...
    what I still need to resolve:
    1. Access the machine thru web interface
    I did a reset using SP5846-047 (cant access SP846-046)
    2. I still dont have the printer option in the machine
    • nysamara
      • Apr 2016
      • 58
      #17
      Re: Multiple Errors
      yes...
      Reset 806182 clear
      Originally posted by gkalman2004
      How do you execute the sp code? How do you enter in service menu ..by typing a code.
      • gkalman2004
        • 157
        #18
        Re: Multiple Errors
        Originally posted by nysamara
        yes...
        Reset 806182 clear
        This is the normal one i say the special sp mode ...
        You don't have print options until you don't do the SP5-985-001 to 1 to deactivate the fiery controler and activate the internal nic to print options
        • nysamara
          • Apr 2016
          • 58
          #19
          Re: Multiple Errors
          Great!!!
          I was able to connect using the Web Interface! the reset worked great!!
          Now I need to resolve just the printer option problem...
          I already set the SP5985-001 to 1... power off/on but I still dont have the option
          • gkalman2004
            • 157
            #20
            Re: Multiple Errors
            Great!!!
            Ok i'm glad to see almost every problem was fixed, now for the printer do you removed the fiery extension card?.
            (and the "fierydriven" from slot1)??
            • nysamara
              • Apr 2016
              • 58
              #21
              Re: Multiple Errors
              This is what I have... which one supposed to be the card? I have two Ethernet connections...
              File 3-26-17, 12 32 25 PM.jpgFile 3-26-17, 12 32 55 PM.jpgFile 3-26-17, 12 33 11 PM.jpg
              • gkalman2004
                • 157
                #22
                Re: Multiple Errors
                [ATTACH=CONFIG]36147[/ATTACH][ATTACH=CONFIG]36148[/ATTACH][ATTACH=CONFIG]36149[/ATTACH]
                I'm not in front of my machine but i think one is the suplimentary network rj45 with the 2screw also open the sd card cover screw and remove the sd card from slot 1 .
                After this check the machine ip from the webinterface i think was the double conection fiery method used with lan cables between the color controler and machine and other lan cable from the machine to lan
                • nysamara
                  • Apr 2016
                  • 58
                  #23
                  Re: Multiple Errors
                  Is the SD card cover slot 1 located there? in the back of the machine?
                  • gkalman2004
                    • 157
                    #24
                    Re: Multiple Errors
                    • nysamara
                      • Apr 2016
                      • 58
                      #25
                      Re: Multiple Errors
                      I found the card... and removed it... but its a PostScript3 unit Type M2 card
                      • nysamara
                        • Apr 2016
                        • 58
                        #26
                        Re: Multiple Errors
                        I removed both... the ethernet card and the SD card
                        • gkalman2004
                          • 157
                          #27
                          Re: Multiple Errors
                          You must find the controler board and remove it
                          Take a look under the fax board, i don't have any other idea sorry.
                          • nysamara
                            • Apr 2016
                            • 58
                            #28
                            Re: Multiple Errors
                            I dont see anything down the fax card... there are only two hard disks and the other pictures are from the other cards...
                            File 3-26-17, 1 39 29 PM.jpgFile 3-26-17, 1 39 49 PM.jpgFile 3-26-17, 1 40 09 PM.jpgFile 3-26-17, 1 40 25 PM.jpg
                            • gkalman2004
                              • 157
                              #29
                              and for E24B ch-c2efi_fsm_final_161216.pdf
                              And the sp 5193-001 must be 0 but write down what was installed on the machine from the 7 types of controller
                              [0 to 10 / 0 / 1/step]
                              0: External Controller is not installed
                              1: EFI, 2: Ratio, 3: Egret
                              4: GJ, 5:Creo, 6: QX-100
                              7: Kurofune
                              8~10: Reserved
                              Ps.. put back the sd card (my mistake)
                              If the fiery was EB34you need to change back these sp's
                              Do the following to prepare the copier for use with the EB-34:
                              • Install the Gigabit Ethernet board in the copier.
                              • Install the Fiery key top on the copier.
                              • Enter SP mode on the copier and specify the correct SP setting to enable communication between the copier and
                              the EB-34.
                              The following SP settings are needed for the EB-34:
                              • SP5193-001:[1]
                              • SP5895-001:[1]
                              • SP5895-002:[0]
                              • SP5985-001:[1]
                              • SP4-201-011[1]
                              • SP4-201-012[1]
                              • Apply the Fiery decal the copier.
                              • nysamara
                                • Apr 2016
                                • 58
                                #30
                                Re: Multiple Errors
                                Wow!!!
                                Thanks gkalman2004!!!
                                everything was resolved!! Thanks a lot!!
