RICOH SNMP
  • keithxxiii
    Just a tech
    • Nov 2014
    • 468
    RICOH SNMP
    Hello gents!
    One of our clients IT had a requirements on all of their network printing devices. The snmp community name should be changed to their assigned values.
    Upon changing the stuff on ricoh devices, printers went offline. Any inputs on this? has anyone faced this issue before?
    BTW: the printing environment does not have a print server. All printers are installed locally.
    Aye! Cut the crap
  • zed255
    How'd ya manage that?
    • 1024
    Re: RICOH SNMP
    In the driver properties got to ports and configure the TCP/IP port with the new community name, or alternatively just uncheck the use of SNMP. Caveat when unchecking SNMP is that there will be no two-way communication, so I suggest when setting up the driver and port that you ensure the community name is correct.
    • keithxxiii
      Just a tech
      • Nov 2014
      • 468
      Re: RICOH SNMP
      Thanks for the input. Have tried in the customer's side...and it seems to be working fine. Now I gave all the loads to them to change the settings on each PC
      Aye! Cut the crap
        • 37116
        Re: RICOH SNMP
        What happens is when the driver on a computer sends SNMP request to the device and does not get a response within a specified time, it assumes the device is off line.
