SC 531 on a MPC 2800
  • fshead
    • 2376
    so i got a call late yesterday for SC 531 on a MPC 2800..
    after looking thru both service and parts manual, I assume it is a possible ventilating fan..
    parts manual only say fans where fans are..
    Are these the two fans on the left side where one would mount
    the big sorter brackets?
    thnx
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: SC 531 on a MPC 2800
    From Goose's Guide:
    SC 531 Ventilation fan front or rear error - check connections to front and rear fan motors
    SC 531 Ventilation fan front or rear error - check/reseat CN 221 on IOB
    SC 531 Ventilation fan front or rear error - replace front fan motor (SP5-804-110) exit end of mach
    SC 531 Ventilation fan front or rear error - replace IOB
    SC 531 Ventilation fan front or rear error - replace rear fan motor (SP5-804-111) exit end of mach
    SC 531 Ventilation fan front/rear error - check connections to front and rear fan motors
    SC 531 Ventilation fan front/rear error - replace IOB
    SC 531 Ventilation fan front/rear error - replace the front fan motor
    SC 531 Ventilation fan front/rear error - replace the rear fan motor
      • 37491
      Use the Point-to-Point to identify where each fan is located. I believe the ventilation fans are in front and in back of the fusing unit.
      • fshead
        • 2376
        thnx i ended up pulling fans from my scrapper mpc3501 and swapping them out yesterday.
        these are the fans on the left side,left of the laser units,ITB cleaning unit etc..they pull air in...and have those little filters in front
        the fram was a little different than the 2800 but i made mods to make them fit.
        the 3501 is a little thicker but connectors the same..
