error SC 819
  • Joelcalatayud
    error SC 819
    Hello friends of the forum
    Maybe someone has the firmware of the ricoh mp 6002 in spanish please
    Thank you
    Why I have an error sc 819 I have already changed hard disk and does not release the code friends help
  • PCC.TONER
    • Mar 2017
    • 13
    Re: error SC 819
    Thank you
    Toner chip, Copier parts, Toner Cartridge - einmay toner
      • 37491
      Re: error SC 819
      There is only one language firmware. When you install it, you have to select the language required.
      • imaginemoko
        unTrusted Tech
        • Jan 2008
        • 289
        Re: error SC 819
        try resetting your controller board, memory first, cleaned if its dusty. worst case casualties could be nvram or controller board.
        fix the customer first then fix the machine... its simple and makes life more easy.
        • service_man
          • Jul 2012
          • 59
          Re: error SC 819
          Did you try to change another HDD??
          Try to rotate memory in slot.
          Try to change FW.
          Change Printer Control Board
          • davel
            • Oct 2011
            • 1104
            Re: error SC 819
            Old thread but you need a trained technician with access to firmware to do it for you.
              Re: error SC 819
              Originally posted by Bebboo
              How can I replace controller firmware? many thanks.
              with that question you asked it is CLEAR you are not a trained technician. You will not have access to the firmware and frankly if you don't know the proper procedure ... you can really screw da pooch.
              bottom line...
              hire a trained tech .
              • sandmanmac
                • 3981
                Re: error SC 819
                bottom line...
                ..and it's his 2nd hijacked thread for the same issue - with 2 month gap in between mind you
                http://www.copytechnet.com/forums/ri...ht=#post606966
