Mpc6502 paper catching
  • barber782
    • Aug 2011
    • 286
    Hi everyone,
    Got a Mpc6502 where the A4 paper lef is getting creased and catching the paper, sometimes even folding when on long print jobs. So far I've adjusted the transport belt height, fitted a spacer on tray one (seen in bulletin)
    Any help would be great
    Sent from my GT-I9195 using Tapatalk
  • HitMan
    • Aug 2015
    • 170
    If this is duplex then there's a little mylar on the shifting plate on the underside of the duplex unit. You can rip this mylar out as it can become out of shape and catch the paper intermittently. You can pull it off with a pair of pliers, just make sure you remove any sticky glue that's left over.
    • barber782
      • Aug 2011
      • 286
      Re: Mpc6502 paper catching
      Hi,
      I'd say its doing it on both double and single sided. But... thinking about it the machine flips the page so it comes out face down in the tray. So I guess something in the exit assembly might be causing it. I will definitely check out that mylar though, good call.
      Cheers
      • zed255
        How'd ya manage that?
        • 1024
        Fuser intake guides can get a ridge of toner buildup that can cause creasing skewing and outright stoppage. As a run progresses the heat makes the buildup increasingly sticky and the problem worsens.
          you can tell if it's after the drum by looking in the crease.. if toner is there... look at fuser inlet or past fuser.
          • Polarbear
            • Feb 2012
            • 1070
            Are the folds flat or not. If flat the paper is catching before the fuser and being pressed flat by the fuser.
            Sent from my SM-G925F using Tapatalk
            Press the GREEN button!!
            • ned.walker1
              Originally posted by barber782
              Hi everyone,
              Exit sponge rollers lose their shape and need replacing periodically.
              Sent from my SM-G935F using Tapatalk
              • barber782
                • Aug 2011
                • 286
                Iv noticed it does it on single sided. I also changed the output to come out face up, and it was fine. So.. I'm guessing somewhere during it reversing the paper. Been looking at the exit assembly and the only thing (which was mentioned by one of your replies) was the grey sponge rollers on exit are a little deformed.
                See pic for fault.
                • ned.walker1
                  8002/6502 exit rollers
                  D135 7166 x4
                  D135 7168 x4
                  D135 7198 x8
                  These are all sponge rollers you need for the exit unit after the fuser.
                  I have had this problem about 4 times in the past.
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    If it always creases on the same place in the paper, you might have an foreign object in the paper path.
                    • Imprestik
                      • Aug 2012
                      • 297
                      Don't even bother trying to rebuild a fusing exit unit on these things its an absolute pain in the bum
                      D135 7009 is the current exit unit, replace the whole thing as it will cover a bucket load of bulletins in regards to jamming as well
                      The image above is the sponge rollers in the E2 gate, they are shaped like a pencil head which gives that crease in the paper
                      • barber782
                        • Aug 2011
                        • 286
                        Thanks peeps. Replaced sponge rollers as suggested and hey presto.. All working fine.
                        I see what you mean about the rollers in e2 gate. Will remember that one for next time. Thanks.
