MP C2800 533 error
  • gkalman2004
    • 157
    MP C2800 533 error
    Hi everybody.
    I have more MP C2800 machines in service but for me is the first time when i receive this error..
    SC533 error but this machine does not have IH inverter coil and fan as far as I know.
    Tomorow i will check the fans but i ask anywhay
    In my case can be the paper exit fan or the machine still has IH inverter fan?
  • COPIERMAN
    • Jun 2009
    • 559
    Re: MP C2800 533 error
    yes it has the inverter fan
    • gkalman2004
      • 157
      I already read the error code from the manual but i don't find in the parts catalog, and i don't remember about this fan on this machine.
      Yes on MP C4000 i have IH coil and fan and inverter board ( is under the front/right part cover)
      but i don't remember to be one on the MP C2800 also i don't find it in the part catalog.
      • gkalman2004
        • 157
        Today i open the machine and i take out every fan for testing and all was ok.. machine dead.
        I check all fuse and was ok .. machine dead
        Finally i change the IOB and this time the machine start up without error.
        And no i don't find any ih converter allmost all fan cables go to the IOB just for the hdd the cable come from the FCU
        So i learn something new
        when you have SC533 for MPC2800 is the IOB controller
        When you have SC204 but the display work the right door ground cable is cutted.
        When you have SC202-204 without working display you must replace R294 from the bicu
        For IOB you must replace R59
        • COPIERMAN
          • Jun 2009
          • 559
          thanks for posting fix, will save tech time in troubleshooting.
