Ricoh MP2852 blank pages
  • OMG
    • May 2016
    • 31
    Machine was having print quality issues so we ordered a new drum/developer unit. Machine prints blank pages with new unit.
    Any help would be appreciated. Thanks.
  • Zeldaman
    • Mar 2011
    • 946
    Re: Ricoh MP2852 blank pages
    Hi there!
    You need a developer type 28.
    Greetings...
    • COPIERMAN
      • Jun 2009
      • 559
      when you remove seals one should had been about 18 inch long maybe it broke off sometimes that happens. also look at back of pcu should see a coupling on mag gear looks kind of grey. try printing counter report in user tools that is an internal print from copier if it prints then optics problem. check to see what you bought includes developer powder.
      • OMG
        • May 2016
        • 31
        I see no seals on this unit
        • gear13z
          • Sep 2011
          • 68
          run developer initialize
          .....with all it shams, drudgery, and broken dreams, it is still a beautiful world.....
          • sturmtrooper
            Copier Combobulator
            • May 2016
            • 587
            That wouldn't make for blank pages, poor copy quality maybe, but there would still be some sort of output.
            • totoro
              • 568
              Call the place where you ordered this new drum unit from and ask if it came with developer installed. If not get some and install it. If it did then you may want to exchange it for another one.
              Totoro
              • Coptech
                worker drone
                • 460
                left the developing drive coupling off? mag roller gears left off?
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  it never comes with developer in it, you have to put it in, as zeldaman already sad.
                  • sturmtrooper
                    Copier Combobulator
                    • May 2016
                    • 587
                    The dev drive coupling is visible in the picture. Since they ordered a complete unit it should still have the gears inside. My bet is as Zeldaman said, no developer.
                    • OMG
                      • May 2016
                      • 31
                      Thanks. Anywhere I can find info on how to do this?
                      • Wild Bill
                        • Jul 2005
                        • 774
                        Your gonna screw up a new PCU assy if you dont know what your doing call a tech, 2 cents worth
                        Izzy
                          • 37533
                          If you were a trained tech you would not need to have asked that questions.
                          • OMG
                            • May 2016
                            • 31
                            Thanks for the help guys. I got it separated. It has no developer. I'll get some ordered.
                            • sandmanmac
                              • 3981
                              Could have also had someone who knows better get you a type 1027 pcu which includes dev, and would have cost a lot less in the end
