MP3350B Finisher Jam Code J130
  • seatac
    • Apr 2017
    • 7
    Hello all, I need your expert, please help me to pin point the problem. This machine work perfectly fine without Finisher (even the finish attached). But when I tried using Stapler or Punch hole option. I got J130 error, paper jam at entrance of finisher. Please see picture.
    By the way, I got error code J100 before. The paper stop at the entrance sensor, but after read few post about switch. now the J100 is gone. This time paper pass about 2" further that where J130 show up.
    Thank you,
  • rudysemira
    • Oct 2016
    • 108
    Re: MP3350B Finisher Jam Code J130
    Thank you,
    I believe your problem is from the finisher as you can see that always stop in the entrance of the finisher, Let us do inspect and clean all paper path sensor this is base on my experience when i am repairing to a finisher only the sensor causing of paper jam and that area has built of dust..........good luck
    • seatac
      • Apr 2017
      • 7
      I try to clean most sensor that I can see and reach with can-air blow and qtip. Is there sensor under the punch unit (it seem like paper stop right at the hole punch)? I will try to remove more part any more hiding sensor.
        • 37533
        Did you change the finisher? I ask this because J100 is a finisher entrance jam for a SR790 1000 sheet finisher and J130 is for a SR3000 1000 sheet booklet finisher.
        • seatac
          • Apr 2017
          • 7
          No, I did not swap the Finisher. The same one come with the Copier.
          • eddy out
            • Oct 2016
            • 359
            perhaps the hole punch is obstructing the path
            • seatac
              • Apr 2017
              • 7
              I will dissemble the hole punch and clean to see if it help.
              Is possible this machine have 120,000 total pages count that why Finisher is end of live?
              • COPIERMAN
                • Jun 2009
                • 559
                finisher last a long time. sometimes hold punch sticks . do you have it set when you make a copy that it goes to top tray of finisher. try direct it to make a staple copy and see if it works. make sure that entrance sensor is working. if you have service manual page 4-147 go into service mode and check entrance sensor to make sure it is working.
                • sturmtrooper
                  Copier Combobulator
                  • May 2016
                  • 587
                  It's easy to remove the punch unit. Try doing that and running paper through the machine before taking the punch unit apart.
                  Could also be that the diverter gates are damaged. They would be just behind where the punch unit is. They control if the paper goes to the proof tray, shift tray, or to the staple tray.
                    • 37533
                    Two main causes for finisher entry jams:
                    1. Slippage in the bridge unit
                    2. Finisher entry guide plate deformed, usually caused by someone using it as a lift point when trying to move the finisher.
                    • seatac
                      • Apr 2017
                      • 7
                      I think #2 is the main cause. when I got it, the Finisher isn't detach, instead hang to the printer with one hook. I guess they didn't know how to disassembly the finisher before ship to me.
                      I will get my hand on the service manual to find out where these guide plate, see I can straighten them out.
                      thanks
