9002 sc 670
  • portviking
    • Sep 2009
    • 18
    9002 sc 670
    replaced the power supply, bcu, controller, eeprom. Nothing changed disconnected the adf and it came back to life for a week. now back to original problem.
  • gkalman2004
    • 157
    Re: 9002 sc 670
    Check the connectors/sensors in the back of the tandem tray, can generate lot of false sc codes.
    • gaudin
      • Mar 2008
      • 39
      Re: 9002 sc 670
      Sometimes the Java Card can cause this Problem, even if its not in use.
      If your Costumer has no Applications installed just remove the SD-Card.
      Good Luck
      Certified for:
      Compita A+ / N+ / S+
      Microsoft MCST / MCA
      • gkalman2004
        • 157
        Re: 9002 sc 670
        ​Any updates? I ask because i also have this machine and it is good to know about what fix you find for this particular case.
        • banginbishop
          grumpy old git
          • Oct 2007
          • 894
          Re: 9002 sc 670
          Just had a mp7502 with intermittent sc670. Powers up but 30 mins later throws a code. Replaced the HDD Probably didn't help trying to flatten the frame with a hammer after the customer bent the fuser bracket guide?
          so far it's ok but we'll soon find out if it's worked.
          Incontinentia Buttocks
