Aficio 2075 to MP 8000 scratched Adf CIS Units
  • Codex
    • May 2008
    • 704
    Hello
    A question....we have a lot of customers with the same kind of problem, if they use the duplex/duplex function from Adf, thin black lines appears on the back side, i know it's the CIS unit (micro scratches on it), i tried to clean them but with mixed success......some works, some not.I'm wondering if there is a kind of "small line removal" setting in SP mode, something like "small dot removal", only for thin lines caused by an scratched CIS unit.
    Memento Audere Semper
  • rudysemira
    • Oct 2016
    • 108
    Re: Aficio 2075 to MP 8000 scratched Adf CIS Units
    Originally posted by Codex
    Hello
    did you test copy on copy board glass if they the same output with a line? if not try little adjust the adf unit..
    • Codex
      • May 2008
      • 704
      The schratches are on the Cis units inside the adf
      Inviato dal mio SM-G935F utilizzando Tapatalk
