Ricoh MPC8002 random toner spots
  • nysamara
    • Apr 2016
    • 58
    Hi all,
    During printing in which cyan or magenta are used there are a few tiny toner spots all over the paper even in the margin area.
  • gkalman2004
    • 157
    Re: Ricoh MPC8002 random toner spots
    Do you read http://www.copytechnet.com/forums/ri...highlight=8002 ??
    • nysamara
      • Apr 2016
      • 58
      Originally posted by gkalman2004
      H!
      From where I can download the MPC8002 latest firmware?
      • Gab
        • Aug 2015
        • 671
        Originally posted by nysamara
        H!
        developer
        • gkalman2004
          • 157
          8002firmware.pdf
          H!
          • nysamara
            • Apr 2016
            • 58
            Hi all,
            I did all the updates to the machine and verified the drum and developer units... there is no mess of toner...
            But I still have toner scattering during printing.
            I did a TD sensor init without changing the developer a few weeks ago... I'm not sure if that is the problem.
            Now if I go to the Vtcnt the values of C and M are higher than the values of K and Y
            same for the values of Vtref
            • nysamara
              • Apr 2016
              • 58
              Update!
              I did a SP3030 just for C and M and I reduced significantly the scattering...
              Any feedback?
              • gkalman2004
                • 157
                Hi you must read the service manual to calibrate the density of the developer (you have old developer and you make td init)
                from chapter 4.12.3 REMOVING OLD DEVELOPER
                • nysamara
                  • Apr 2016
                  • 58
                  but that will just help me to reduce the amount of toner in the unit but there
                  Is no instruction of how to calibrate it. I currently have a density within spec.
