Need help fof Ricoh Aficio 2035
  • pmtvn
    • Oct 2008
    • 16
    Hi all,
    I have just bought 2nd hand Ricoh 2035, I have downloaded drivers from Ricoh but I could not find Document Management utilities
    CD-ROM 2 "Scanner Driver & Document Management Utilities"
    as its mention in the manual, I have search on the web and also the forum but I could not find.
    Can someone please send me a copy or give me the link to download.
    (my email hung.vietnam@gmail.com)
    thanks for your help,
  • rthonpm
    • Aug 2007
    • 2859
    The only things on the CD were the TWAIN driver and Desktop Binder. Both should be available from the Ricoh website, along with SmartDevice Monitor.
    • pmtvn
      • Oct 2008
      • 16
      Hi Rthonpm,
      Great help, thanks, I found it, downloading now.
      But I have Lite only, for the pro. I need to buy.
      thanks agian,
      • nmfaxman
        • 1702
        Lite versions are great for small business.
        Big business can afford to buy PRO versions.
        • pmtvn
          • Oct 2008
          • 16
          I have a small office so Lite is good enough.
          I will install and try to use it. Hope it easy.
          one more question, when I install the Lite, is it come with all driver? Do I need to install driver?
          Thanks all,
          • nmfaxman
            • 1702
            Twain is a self installing program.
            Desktop binder is a self installing program.
            RPCS driver and lanfax driver are user installed.
            Install Twain program, then RPCS driver, then lan-fax, then Scanrouter Program.
            Last install desktop binder and go through the one time setup and let it find the other drivers.
            Tying all the OEM software together with Desktop Binder gives great functionality to the small business owner.
            Check the Ricoh website under solutions for scanning with XP SP2.
            It shows the way to get past windows firewall.
            • pmtvn
              • Oct 2008
              • 16
              Hi Nmfaxman,
              Thanks for the instruction, but pl. explaine to me what is Scanrouter Program, I have been to Ricoh but only see PCL is out of yor list,
              Is is PLC = Scanrouter Program.
              And there are PLC 6 & PLC 5e which one can be use or I need to install both?
              link is http://support.ricoh.com/html_re/model/x2035_2045/x2035_2045en.htm#Microsoft%20Windows%20XP
              Thanks,
              • Scott_Lewis
                • Mar 2007
                • 519
                Help yourself
                You can find a copy of ScanRouter Lite here
                • pmtvn
                  • Oct 2008
                  • 16
                  dear Scott Lewis,
                  Tks, I have Scanrouter already.
                  Because they are clearning the machine now, I should have it tomorrow and I will follow the about instruction.
                  One more question: Do I need to install PCL 5e or PCL 6? And what is it?
                  Pl. help, tks,
                  • petrus
                    • 155
                    this pcl5e or pcl6 is for the printier only.u can use either of them which compartable to you pc.its a printer controller language.
                    • pmtvn
                      • Oct 2008
                      • 16
                      As you mention, I don't need to install them while I follow the about install sequence?
                      • Scott_Lewis
                        • Mar 2007
                        • 519
                        Correct. The print drivers are not related to the scan functions.
                        • pmtvn
                          • Oct 2008
                          • 16
                          But I need to use all funtions of this machine Copy-Print-fax-scan,
                          so do I need to install PCL6?
                          • Voltage
                            • Jul 2008
                            • 282
                            With a 2035 Scanrouter is going to be the least of your problems.
                            • Scott_Lewis
                              • Mar 2007
                              • 519
                              You can install the PCL6 anytime you like. Just saying there is no critical order that it must be done.
