Ricoh MP CW2200SP print missing alternating rows
  • djteck
    • Feb 2010
    • 19
    Hi to all. Servicing a Ricoh MP CW2200SP that seems to print only in one direction. Attaching a sample. This happens black only - color seems to print ok. Performed the clean and flush procedure in the user tools. During flush got an sc220-03 code. After reboot print quality was fine. After a few days the customer has called again - the problem has returned. I am thinking the printhead may be faulty but would like to know what you folks think. Thanks
    Counters: color 609, b\w 5568Attachment 36432
    Thank you slimsbob for pointing out my error in posting this thread
    Re: Ricoh MP CW2200SP print missing alternating rows
    how many time did run cleaning on PH?
    it does look like that to me also... is this a liquid or gel ink?
    • mikadonovan
      • May 2008
      • 2931
      I have one of these damn things, too. It looks like you are missing print from K1 or K2. Run a test pattern and see which k head is not printing. Clean that head. Run another test print. Repeat 3 times, or until pattern is smooth with no broken lines. IMPORTANT: run a test pattern after every cleaning, and flush (if you have to flush). The entire procedure is in the manual, and you have to follow it to the letter to achieve desired results, including waiting 10 minutes after a flush before running another test pattern. You have to have patience with this ink beast. I don't think I have ever had a service call on it that took less than an hour, sometimes more. Also, get on TSRC and find the bulletin that deals with "early printhead replacement." It has a set of SP's to change that schedules the machine to automatically clean the printheads. It does help a lot.
      NEVER ASSUME ANYTHING
      • djteck
        • Feb 2010
        • 19
        Hi Phil. Slimslob informed me there is a bulletin on this issue. I ran head cleaning a number of times and getting good print. Will get bulletin and go from there. It's liquid.
        • djteck
          • Feb 2010
          • 19
          Thanks Did just as you said. Will get bulletin ASAP
            yeah those gel units were bitches.. glad it werked out
