A3 double click - MPc 8002 and Pro c5100
  • Timmytronic
    • Oct 2010
    • 249
    Hi, Does anyone know how to change the A3 double click on the MPc 8002 and Proc 5100 range machines. I have three machines in one place and one is double clicking and two are not. The customer is aware of this, they don't do a lot of A3's anyway but I wanted to switch it off the one machine and can't see it in the manual or in the SP mode. It use to be in SP 5 on older machine with you holding down a key when you went into the mode but I can't seem to do it on these types now.
    Thanks for any help
    Tim
  • Brianneoe
    • May 2015
    • 322
    Re: A3 double click - MPc 8002 and Pro c5100
    SP mode 5104-001 should be set as a 1. That is the default value from the factory. It is also noted that this does not apply to the bypass operation.
    Good luck
