Ricoh mp cw2200sp - sc282-11
  • Dawid130
    • May 2015
    • 7
    Hello,
    I encountered a SC282-11 bug on my device. According to the manual, this is a leakage error on the ink pipe and the error is not deleted until it is removed. Ink is flowing from the machine. The ink is really a lot. It flows in the maintenance unit. It is heard that the maintenance unit pump does nothing. Do not you know what this bug is watching? How is it evaluated? How to prevent and remove it?
    Thank you for your advice.
  • mikadonovan
    • May 2008
    • 2931
    Re: Ricoh mp cw2200sp - sc282-11
    You have an air leak related to print head 1, probably why the ink is leaking out. Fix the air leak for starters.
    NEVER ASSUME ANYTHING
    • Dawid130
      • May 2015
      • 7
      Yes, I found out that the pump does not work on the maintenance unit. Just I do not know why and where the air leak.
