Ricoh MP C4000 - SMB Scan
  • savi0r
    • Sep 2010
    • 363
    [Misc] Ricoh MP C4000 - SMB Scan
    Hello. If someone can help me, i would be really gratefull. I am in need of firmware for ricoh mp c4000. While browsing the network from the machine, i am dealing with " cannot find the specified path". And i would really like to set it this way, through SMB. Thank you
  • Codex
    • May 2008
    • 701
    Re: Ricoh MP C4000 - SMB Scan
    Hello
    What S.O do you use?, have you tried to setup the path manually? (\\computername\sharename)?
    Memento Audere Semper
    • savi0r
      • Sep 2010
      • 363
      OS is Win7. I had this issue before on a 3245c and the firmware fixed it perfectly. My current firmware version is :
      Printer : 1.21
      System : 1.21
      Engine : 1.56
      • Ben Around
        • Apr 2012
        • 151
        Printer : 1.21
        System : 1.21
        Engine : 1.56
        Updating the firmware should do it.
        Check your PM for a link I sent to you.
        • TonerMunkeh
          Professional Moron
          • 3865
          Check the machine has DNS and domain entries in interface settings. Try browsing the folder from the RUN command of a computer. Make sure the username and password are valid on the machine / server you are trying to scan to.
          Hit it.
            • 37383
            "cannot find the specified path" usually means that you do not have rights to the Host and/or folder. Check the name and password you are using.
            • guitar9199
              • Sep 2016
              • 1100
              Something else you might need to check. Windows 7 enables NetBIOS over DHCP, and that will sometimes make SMB a little hard to set up. Go to Network and Sharing/Network Card/Properties/IPv4 Properties/Advanced, click on the WINS tab, and check NetBIOS over TCP/IP and see if you can configure your scans then.
              ...fought with one for 2 days until I discovered this little nugget on a Microsoft forum!
                • 37383
                I have also found that on a domain, the first DSN entry should be the local domain DNS.
