MPC 2004SP Scan to Folder with OSX 10.9-10.12
  • PillePalle
    • 42
    Hi Guys
    I got a few Problems with scan to Folder and this MPC2004SP an OSX.
    The Last Version that i was able to get it working is. 10.9. Can someone confirm that with the later Versions scan to Folder is not Working? I don't want to spend hours in testing if its not going to work anyway.
    Thanks in advance for your help
  • COPIERMAN
    • Jun 2009
    • 559
    Re: MPC 2004SP Scan to Folder with OSX 10.9-10.12
    Check the sign in apple new software originaly was smb sign in enable and required and now has smb1 sign in enable and required which also needs to be false. Here in united states i have done this and works fine so long you did changes that ricoh says to do. They haven't update info about smb1
      • 37532
      http://www.copytechnet.com/forums/co...ighlight=samba
