SC544 error message displayed on MPC4502, used fuse M0264371 and SP 5810-002 to reset the error but "failed" appears immediately after I press Execute and nothing happens. Thermostats and fusing lamps are good.
SC544 on MPC4502
Re: SC544 on MPC4502
It is possible to plug the fuse into the thermistor connector and the thermistor into the fuse connector. that will give you the results you describe, 5810-2 will fail. the two connectors are identical!!!!!!!!Mystic Crystal RevelationsComment
elite2travel
To reset sc 544 need a pico fuse that comes in a rebuild kit for sp5- 810-2 to work otherwise show fail
Sent from my iPhone using TapatalkComment
At least 50% of IT is a solution looking for a problem.Comment
