Ricoh mp 1075 blown fuse104
  • vedran2008
    • Feb 2017
    • 7
    Please help. Ricih .1075 display no work light on only led for stand. By.In power suplay fuse 104 is blown but i changed angain is blown .PSu. is problem or copier . Please. Help where is. Problem thanks gay .
  • Zeldaman
    • Mar 2011
    • 946
    Re: Ricoh mp 1075 blown fuse104
    Hi there!
    If you like it or not, the best way (i.e. not the easiest) is to take the point-to-point-diagramm. There must be a cn on the board for which the fuse is build on. Playing a little bit "Sherlock" then you see which part causes the blown fuse.
    Greetings...
    • vedran2008
      • Feb 2017
      • 7
      when disconectet conector 119 no b;lown fuse what is problem but idon now waths is proble
      • davel
        • Oct 2011
        • 1107
        • sharpmind
          • Sep 2009
          • 478
          There is a shorted component in the power supply.Check the integrated components with heatsink whether it is good or not.
          • rudysemira
            • Oct 2016
            • 108
            Check the power supply board if there is nothing shortage component like diode and check the varistor this is also protector for short circuit or you inserted not the same amperes of fuse.....is this 220 volts?
            • vedran2008
              • Feb 2017
              • 7
              When turn on ricoh the fan under power suplay start and stop and like riley click for protection and blown fuse
              tomorow i going to anather ricoh 1060 wit same ps to sample ps for to see if it ps is up or something else
              Thanks koleg thanks gay
              • vedran2008
                • Feb 2017
                • 7
                the power suplay is ok but not start only
