Ricoh 2075 Heavy background or Negative Copy
  • scenicmike
    • Feb 2014
    • 13
    Hi to all!
    I have the following problem. The machine is a Ricoh 2075.
    Everything is clean and I've tried to change drum, developer module, charge corona, transfer assy, with no result.
    Heavy background or Negative copy.jpgAny ideas?
    Re: Ricoh 2075 Heavy background or Negative Copy
    did you reset the bias for the new drum? reset dev bias?
    have you tried starving the developer by doing sky shots and then re-tone the developer?
      • 37533
      This used to be a problem with early plain paper machines. Not all manufactures used the same charge polarity on their toners. My guess is that you are not using Genuine Ricoh toner, developer and drum. Either that or the HV power pack is bad or connected incorrectly.
        • 37533
        If it is a bias reversal problem, sky shot will come out blank. Checker flag is better for depleting toner.
          wow learn something new everyday... never had "blank" skyshots
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            I agree.
            It's been many years, but I can remember several calls for this very problem that turned out to be bogus "competitive" toner.
            • scenicmike
              • Feb 2014
              • 13
              This used to be a problem with early plain paper machines. Not all manufacturers used the same charge polarity on their toners. My guess is that you are not using Genuine Ricoh toner, developer and drum. Either that or the HV power pack is bad or connected incorrectly.
              All parts are genuine! Toner and developer. Only the drum is a Katun Performance. And after the problem, the machine is vacuumed and everything is clean.
              I 'm in a dead end!
              • scenicmike
                • Feb 2014
                • 13
                I don't know if anyone notices that there are no border deletions. And sky shot is completely black!
                  • 37533
                  I 'm in a dead end!
                  Then your only other source the the Katun drum does not have the correct coating.
                  Anytime you have a background problem there are no borders, i.e. if other white areas have background, so will the borders.
                  • Lagonda
                    • Aug 2008
                    • 1649
                    Check the bias contact and the drum earth. If it still has a problem put the old drum back in and see what happens.
                    • scenicmike
                      • Feb 2014
                      • 13
                      I 'll check it and i will let you know!
                      • NeoMatrix
                        Senior Tech.
                        • 3513
                        I'm incline to agreed with Lagonda....
                        Looks similar to when a staple is stuck to the dev roller/doc blade, or worn bearing/metal shards short out the developer unit bias.
                        HTH
                          I 'm in a dead end!
                          get a real drum... katun drums are crap
                          • usta
                            • Oct 2013
                            • 44
                            Check the cables from the adf unit to the back cards. We met. The problem was solved when we changed these cables.
                            • Codex
                              • May 2008
                              • 704
                              check the corona bias...had a similar problem and in my case it was the charge bias
                              Memento Audere Semper
