MP2501 HDD wipe
  • micdelbo
    • Dec 2013
    • 18
    MP2501 HDD wipe
    Hoping for some help here. I have been tasked with finding out how to wipe the HDD's on Lanier mp2501's.
    We are not a Ricoh/Lanier/Savin dealer, but we have a prospect that is looking to upgrade with us and does not want to deal with their existing dealer. They are in the healthcare field and need to have their HDD's wiped on their machines before they are returned to the lease company for HIPPAA compliance. I am sure there is security software from Lanier that will do it, but again, they don't want to deal with their current dealer.
    We offered to remove their HDD's and have them wiped/destroyed and install replacement drives. I know on some machines this is easy and on others not so easy. How is it on the mp2501i?
    I also know we will need to have the software/firmware updated to make the machine operational. How is that done?
    I have told the sales rep the software method is the easiest and probably the least expensive in the long run.
    Any input is appreciated.
    Thanks,
    Mike
  • mikedci
    • Jul 2010
    • 227
    Re: MP2501 HDD wipe
    The 2501's don't come with HDD's unless you also purchase the HDD Option type M1. The HDD option also comes with DOSS and HDD Encryption and if it was installed its a simple matter to run the Erase all option from user tools. Ricoh firmware isn't on the Hard Drives so you shouldn't have to worry about that.
      • 37385
      Re: MP2501 HDD wipe
      Most Ricoh HDD are off the shelf drives. They can be caddie mounted and formatted by a computer. Once placed back in the MFP, it will detect that the drive is blank and install the needed folder structure.
      • micdelbo
        • Dec 2013
        • 18
        Re: MP2501 HDD wipe
        mikedc1-So how do I tell the sales rep to see if it has the HDD option? Will a status page or report show the installed options? Is the drive easily installed? I know on our older Kyoceras the HDD slid in the side of the print system.
        "Most Ricoh HDD are off the shelf drives. They can be caddie mounted and formatted by a computer. Once placed back in the MFP, it will detect that the drive is blank and install the needed folder structure."
        slimslob-So I assume our memory supplier (Memory Experts) can get the HDD. Also, do they need to be formatted on a pc or can it be done in the copier?
        Your replies are much appreciated.
        Mike
          • 37385
          Re: MP2501 HDD wipe
          Print SMC diagnostic report, SP 5990-005. It will show if there is a HDD. If it does not have a HDD you will the HDD option kit. Includes the drive, mount plate and cables needed. If it does have a HDD but you want to replace it, look at the information plate on the drive. It will show make and model of the drive. Anything of the same or larger size will work. 2501 will recognize that there is a new drive and prepare it automatically.
          • Elmo
            • Feb 2010
            • 541
            Re: MP2501 HDD wipe
            HDD install doc
            I Used To Live To Fix Things Now i Fix Things To Live
            • mikedci
              • Jul 2010
              • 227
              Re: MP2501 HDD wipe
              If you're having the sales rep check for hard drives they can print a config page to get the info and they won't have to enter service mode. user tools/counter > printer features > configuration page.
              • micdelbo
                • Dec 2013
                • 18
                Re: MP2501 HDD wipe
                So the sales rep printed the config page and it doesn't show an HDD. It shows 4 meg of RAM disk so I assumed that also meant no HDD.
                Where on the config sheet would the HDD show if it was installed. On Kyocera's, the status page shows HDD---"not installed".
                Mike
                • COPIERMAN
                  • Jun 2009
                  • 559
                  Re: MP2501 HDD wipe
                  Print out config page on two ricoh mp 161 and mp c3300 no where does it show a hard drive. I know the mp161 doesn't have one and mp c3300 does. Best thing is to look visually. The hard drive is mount on network card unit. pull it out and take a look of course may sure power is off.
                  • mikedci
                    • Jul 2010
                    • 227
                    Re: MP2501 HDD wipe
                    Hdd shows at the top under system reference
                    20170530161525387.pdf
                    this one doesn't have one. if it did it would say hdd in the highighted area
                      • 37385
                      Re: MP2501 HDD wipe
                      The best printout to use to check if there is a HDD is SP 5990-005.
                      • Polarbear
                        • Feb 2012
                        • 1070
                        Re: MP2501 HDD wipe
                        [ATTACH=CONFIG]36732[/ATTACH]
                        Generally speaking, if the machine does not show a DOCUMENT SERVER it does not have a hdd. As the document server shops up when a HDD option is installed.
                        No Document Server = no HDD.
                        Press the GREEN button!!
