Here's a strange one loud noise from ITB cam mech,seems cam motor staying on,folLowed by SC 442,tested motor/senor in input/output mode all seem to be fine,swopped ITB unit,still the same so I can rule that out,as soon as the machine starts up does a self check the loud noise starts followed by SC 442,any thoughts? Going back today with Magenta toner supply unit,gear bracket & sensor.
SC 442 MP C 5503
Tags: None
Re: SC 442 MP C 5503-Solved
Magenta PCU was the culprit-blocked waste toner coil-coil twisted,this was after the waste toner mech was all blocked up as well as the K PCU waste coil,vacced out waste toner assembly,ran in output mode to make sure no broken coil & checked all other pcu's-fitted new magenta PCU,machine back up & RUNNING!Comment
