E22C Fiery Color Controller
  • ITDirector
    • Aug 2025
    Hello, I am trying to setup a E22C Fiery Server For an MPC 4503 and MPC 5503. I cannot get it to connect in any way except to reload the system software through a crossover cable via laptop. When I cannot to regular network and then the copier via crossover cable I cannot get it to show up on the network. I have a keyboard and monitor connected to the fiery and I cannot get into any settings to set the IP or anything else for that matter. All I get is the PXE Shell or it will try and boot from the network and it looks for DHCP. I have the system software disk and the user tools disk but neither contain technical info. Please someone help me with this. Its very annoying!
    • 37556
    Re: E22C Fiery Color Controller
    Do you have the Color Controller Connection Board Type M4 Fiery Connection Board EDP Code 416733 installed on the MP C4503/5503? Are you following the Installation in the D730 (Fiery E-22C) Service Manual exactly? If the answer to either is NO, hire a trained and qualified tech.
    • ITDirector
      E22c
      Hello and thank you for responding! The answer to question one is yes sir and I've turned off the NIC on the printer. The answer to question 2 is I don't exactly have that (could you possibly provide a copy or link?) And I'm more than qualified with the right documentation I've just never set one of these up before. Am I correct in saying that the Ricoh MPC 4503 should see it and display a fiery button on the main home screen? I cannot get this to happen. What exactly do I need to shut off/on on the copier? Could you call me and talk with me for a couple minutes so I can pick your brain? Either way thank you so!!! 407-705-8453
        • 37556
        Re: E22c
        If you with are an authorized Ricoh dealer or tech, you can download directly form rfg-esource. Otherwise I suggest that you either contact your nearest authorized dealer or call EFI Support 855-334-4457.
