RICOH MP 301SPF with SC 997 00
  • aktasson
    • Feb 2017
    • 201
    Hi there!
    we have a Ricoh MP 301SPF with the error code 997. Power off and on the machine doesn't solve the problem. The device has no function, no pc printing, scanning and copying possible.
    Has anyone ever had the error? Thanks.
    Regards,
    Aktasson
  • Qball
    • Jun 2013
    • 127
    Re: RICOH MP 301SPF with SC 997 00
    Originally posted by aktasson
    Hi there!
    Regards,
    Aktasson
    997 is a controller error. You can try firmware or sometimes I have luck if I remove all extraneous accessories or options like the fax option then try to power on. If that fails then you're probably looking at a new controller.
    • Kevbhoy
      Hi there!
      Regards,
      Aktasson
      I dont know about the MP301 but I have had memory Dimms causing sc997 on other Ricoh devices so maybe take off and power up, clean contacts of Dimm and reseat? Then as Qball says, it may need a controller
      • COPIERMAN
        • Jun 2009
        • 559
        try pulling network /fax box sometimes will fix problem.
        • aktasson
          • Feb 2017
          • 201
          Thanks guys for the tips.
          Ok i will do following steps first next day:
          (starting the machine without plugged network and fax cable!!!)
          1. if possible, firmware update with all fwu files
          2. adress book backup in sp, then initializing the address book in sp
          3. Disassemble options Faxboard,Memory ext., SD extensions etc.
          We'll wait and see what happens...
          • keithxxiii
            Just a tech
            • Nov 2014
            • 468
            This happened to me a lot of times. Removing the fax unit and the optional Java TM fixes the problems.
            PS, update the firmwares also
            Aye! Cut the crap
            • aktasson
              • Feb 2017
              • 201
              Very very strange, I shut the device down and unplug the power cable, network and fax cable. After that i have push the power button in order that the psu properly discharged from residual voltage.
              I started the machine then with inserted sd card. There was no sc displayed so i could do the firmware update.
              After restarting with network and fax cable, no error message came out. Testprints over pc and machine, testscans to folder work perfectly. I hope it stays that way :/
