Hi All.
Been a while since my last visit here. Wanted to find out if anyone has had a problem with the drum shaft wearing out on this model at around 1.5mil. This has caused the machine to dump shed loads of toner in the PCU and generally crap C/PQ. I also suspect that this was the cause of some intermittent electrical issues, i.e. SC204, even after the mirror and board replacement, then suddenly stopped. Also had an issue with the timing in the finisher causing it to booklet staple out of alignment and the ejector belt to misfire, causing dents in the paper and jams.
On the advice of the Ricoh boys I replaced the drum shaft and bracket. Previously there was little to no continuity between the shaft and the contact plate on the rear. After replacement, perfect continuity.
1.5 mil seems rather soon for it to fail considering the volume this machine does.
Any thoughts.
Have a great weekend
Any thoughts.
