MPC 2551 switched to e-40 error
  • usta
    • Oct 2013
    • 44
    MPC 2551 switched to e-40 error code while installing new software to the machine. I tried to install new software with another sd card but it is not loading. Error code in progress. Can there be help? Thank you
  • usta
    • Oct 2013
    • 44
    Re: MPC 2551 switched to e-40 error
    Originally posted by terramobil
    E-40 means engine module firmware download failed. You can try to use WIM (.rfu file) for update.
    The machine does not accept the installation of new software and it always goes to the same fault.
    • usta
      • Oct 2013
      • 44
      The EEPROM on the BCU was changed and the problem was resolved.
      • arahael
        • Mar 2013
        • 97
        There is normal way to cancel load firmware.
        • usta
          • Oct 2013
          • 44
          How it is made
          • arahael
            • Mar 2013
            • 97
            1-4-3 then Red "C"x10
            Wysłane z mojego Redmi Note 3 przy użyciu Tapatalka
