MP C5503 SP mode
  • kccopierguy
    • Dec 2011
    • 3
    MP C5503 SP mode
    MP C5503 cant enter SP mode with reset 806182 clear. Can with reset 143 clear clear. Any ideas? Thanks in advance.
  • zed255
    How'd ya manage that?
    • 1024
    Re: MP C5503 SP mode
    SP mode sequence can be customized on the models using the new sequence. Perhaps it has been changed? Alternatively, has SP mode lock been turned on in user tools?
    • kccopierguy
      • Dec 2011
      • 3
      Not the mode lock I even turned it on to try. It beeps if it is on after entering code. Didn't know about customization. Can I set it back to default? Or do I just re-customize it?
      • johnyb
        • Feb 2011
        • 167
        In SP 5081 the service mode access code can be changed from the default 806*** to anything numerical.
        If this SP setting has been changed then the only way to access service mode to change back is to enter the new code.
        *43 factory mode wont allow you to reset the SP access code, the setting is not there to change it.
        You could try SP 5046-046 in factory mode, but I don't think this will work.
        Other than that, NVRAM unless anybody knows better!
