Scan double sided to single files.
  • MarketyMark
    • Aug 2025
    I'm setting up scan to folders on our Ricoh Pro C5100S copier and I could use some help getting things to work.
    I need to scan a stack of double sided pages, with each page (2 sides) ending up as a separate PDF file.
    I can get each side to scan as a separate file and I can get the whole batch to scan as one file. I just can't seem to find the setting that will allow a stack of double sided documents to be scanned in as separate 2-page PDF documents.
    Any advice on getting the settings just right is very much appreciated.
  • mikedci
    • Jul 2010
    • 227
    Re: Scan double sided to single files.
    On the MP C5502 in our office if i set the default scanning to multi page pdf then under original feed type set it to 2 sided original and divide to 1 sheet it will accomplish this.
    As a disclaimer I've never seen a Ricoh Pro C5100S so not sure if those options are available on it...
    • MarketyMark
      That did it! Thanks a ton for the help.
