MPC3003
  • GeorgeBest
    • Jul 2009
    • 526
    MPC3003
    HI,
    Does anyone now which Printer BIT SWITCH disables the message when for example you print a normal print job
    to an paper cass which has "Medium Thick paper" programmed in the tray paper settings.
    Thanks in advance .
  • davel
    • Oct 2011
    • 1104
    Re: MPC3003
    Change setting in printer properties to the correct paper type or to the correct tray.
    • HitMan
      • Aug 2015
      • 170
      I think you can set in printer settings on the copier, auto continue to immediate and it will take the paper from the specified tray
        • 37495
        Re: MPC3003
        Also in user tools change change all the trays from Machine Setting to Driver/Program.
