SP 4510 toner problem
  • solorajder
    • Jul 2010
    • 106
    Costumer install new toner and printer works fine. After about 1 hour printer stops and write"Add toner" on display.
    I was thinking that was something wrong with toner, so I adviced costumer to install new toner. Printer again works fine for about 1hour then stops, "Add toner" again.
    Does anybody have the same problem?
    When the toners was inserted to the printer, the Id chip was reseted and now this toners is not recognized by printer any more.
    Is it posible somewher in SP to tell printer that it have a new toner?
    Sent from my GT-I9195I using Tapatalk
    • 37652
    Re: SP 4510 toner problem
    In the future, do not post the same question in both Ricoh MFP forum and Ricoh printer forum. Us grumpy old men just might start ignoring you.
    • BEBEDELFUTURO
      • Jul 2017
      • 34
      Son los pines.
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        Instruct the Costumer to change costumes...dressing as Batman is never a good idea unless you're Batdad..!!!!
