I have a mp c3002 that is skewing the pages slightly while passing through the adf single sided. Copies are fine from the glass but for the life of me i cannot get this to not skew and it is very frustrating.
Obviously i believe that either rollers are not cleaned properly, or something is in the paper path ever so slightly, but I have done my due diligence on that end of things. I have cleaned all rollers in the adf thoroughly and replace paper feed belt and reverse roller as well. Then i completely switched the whole document feeder with another one, did the same (clean rollers, replaced pf belt, etc.) and the dang thing is still pulling in papers slightly crooked. I have messed around with the skew adjustment in sp 6-***-*** but nothing seems to be helping this.
Customer has a document with borders right on the edge of the printable area, so when he copies it, if it skews even a little he loses one of the borders and he cannot have that. Anything helps! Thanks!
